Facing Issue With Error Code 0x800710E0
Every time I tried to run my program, there is an error 0x800710E0 on server 2012. My system account is a member of local admins and has FC rights as well. What should I do?
The operator or administrator has refused the request (0x800710E0). This error statement-making your system weak.
You can try the following ways below to avoid such error;
1) By setting user permission
2)By changing the power setting
• By user permission
a) Create task
b) Select the right user account.
c) Enable the option- “run whether the user is logged on or not.”
d) Right-click on the application and select properties.
e) Go to the security tab and click on edit.
f) Allow access to the user by checking the permission box.
Notifications
