Facing Microsoft project trial activation error
I am facing microsoft project 2010 trial version activation error problem. How can I solve this activation error problem? Can anyone have any idea how to activate it without any error?
Hi Natanne Lopes,
I understand your issue and the problem is, sometimes computer creates some log/ temp files that may cause these problems may occures.
I recommend you please follow these steps to delete temp files and activate the trial version :
then again try to activate the key in your microsoft project 2010.
I hope it may helps you. Thanks!
I think you are referring to the error code “0xC004C032” that you probably received when you tried to activate a trial version of Microsoft Project 2010. Actually, you will receive that error in any Microsoft application during activation of a trial version. You normally encounter that when you are trying to activate a program on more than one computer.
The error code “0xC004C032” means that the activation server reported that there is no new time-based activation available. The usual workaround is to install the program in only one computer. Another workaround that worked for some users is to uninstall your existing version and download a new version. Try downloading Microsoft Project 2013 Trial. This might also work. Click Start, Control Panel, and then “Add or Remove Programs”.
Go along the list and select Microsoft Project 2010. Click Change then you should see an option on the next screen to activate the program. Activate the program and see if it works. Additionally, when you are prompted to activate online, select the option to activate on your PC. This worked for some users as well.
