Wood Rebeca
Posted on - 02/21/2013
I am using acronis 7 to make backups. First everything is going very well but after using 1-2 months it is now creating problems to create backups. It seems that it is doing nothing. Can anyone tell me why this is happening and how to solve this problem?
Facing problem to make backups by using acronis 7.
I think it's been infected with viruses.
You can check your security system as well as other requirements like space availability. After all, if there is no problem yet, you can uninstall your PC's antivirus.
Then, clean your PC's registry using Orbit System Care. Finally, you can reinstall Acronis 7 and hopefully you will be able to do it with no more hassle.
Enjoy it!
