How to improve my Odesk Job application?
Please help me with the following problem:
I have an account in Odesk , but my account completion percentage is very low
Also I have a poor job quota
What I can I do?
What I can I do?
You have asked a great question. Its solution is easy. Follow the following steps:
1. Go to your Odesk contractor profile and upload a photo for 20% advancement of your profile.
2. Add the skills you have.
3. Add Brainbench certification and other certification.
4. Add portfolio project which will increase your profile
5. Take a test which will complete your 100% profile.
Hope you will be able to make your profile 100% very soon. Â
Thanks for your answer.
Can you help with my job quota? It is 2 per week .Very poor isn't it?
Thanks
Oh it's simple…..
If you take your Odesk readiness test then it will be solved. Then you will be able to take 15 jobs per week that means job quota will be 15 per day.
This is an open book test. So I think you will not face much difficulty.
Thanks
Oh thanks for the response. I have also been facing problems with my Odesk free skill test. I have tried several times and failed what to do can give any suggestion?
Thanks
It is the common problem facing by all new Odesk users .So don't be frustrated. Try the simple spelling tests which will primarily make your profile 100% and you will pass I think because it is very simple
Hope your good days.
Thanks
Thank you both for your kind information; hope I can solve my problems now.
Thanks
At first you should complete your profile 100%. Then you should participate many tests. After passing many of the tests you can bid as many works in Odesk. And this you can increase our job application.
Hi Saidur,
It is really a very big problem for the newbie’s to increase job quota and make profile 100% complete. But you have to do it if you want work. Please do the things that Odesk tells you to do and make your profile picture. Give readiness test, skill tests, add certificate, add portfolio, and add educational background to make profile 100%. Id verification is need for increasing job quota. Thanks.
