anonymous
7060 points
Posted on - 08/11/2011
Whenever I click on my internet icon I get this script error "line 16 access denied" and internet does not appear . If I log off computer and log back on then it works. But few hours later it pops up with the same problem.
Facing a script error message
Hello Rose,
Line 16 access denied script error in your Internet Explorer issue; Follow these steps and this will fix the problem
• Click Internet Explorer
• Go To Tools, Internet Options
• Advanced Tab is the next to Click
• Click on the bulleted point on Disable Script Debugging
• Get rid of the check mark on "Display a notification about every script error” You need to close the Internet Explorer and Reboot your computer.
Try again, pull up your browser and if it still popping up click Yes once and close the browser. Do not click the Yes button more than once as it will happen again soon. This should be the fix for this as I've tried it myself before posting this comments.
