Facing Website Certificate Error – Untrusted SSL Certificate
Hi when I’m trying visit a web portal it show an SSL Website certificate error. So help me to unblock this problem. Thanks in advance.
Hi, when you try to visit a website which was located under-restricted zone such as intranet zone. You can open the website by clicking continue. So please be aware of the website address after Continue to the website such as try to add www. After HTTPs, and do not enter any private information. After Continued to website address bar appears in red color. Click there an information window popup, click View Certificates to install Certificate, a warning message box appears so click yes to proceed (for Vista user run IE as administrator).
If you encounter an SSL-related error when you visit a website, the problem there is with the website’s SSL certificate which you have no control over. An SSL certificate is required if a website wants to shift from being in “http” into “https” which is used by banks, government, and other secure websites.
If a website started in “http” for many years, transitioning to “https” will take some time to finish. If you are using Windows Internet Explorer when you encounter the SSL error, try using a different browser like Google Chrome, Mozilla Firefox, Opera, or SeaMonkey.
If you are connecting to a secured website or to a website that uses a secure connection, try changing the protocol prefix from “https” to “http” in the address bar to connect to the website using unsecure connection. This sometimes work when there is a problem with the SSL certificate. There are two types of prefix used by websites to define access:
Notifications
