Facing Windows Error Code 80070643, Updating Failure
I was trying to update the Windows, but it is showing failure. The screen displays Windows Error Code 80070643 while updating. How to solve the error?
The error occurs when you use Windows website or updates to install the update.
I
II
If the above steps do not work then follow these steps –
You may receive error code “0x80070643” when you try to install Microsoft Security Essentials, Windows Live Essentials, or a specific Windows Live application such as Windows Live Messenger. The problem happens because the previous installation or the old installation puts the computer in a state where there is a pending restart. To fix the problem, try restarting the computer then reinstall Microsoft Security Essentials.
When reinstalling, don’t uninstall the existing version. Just run the installer of Microsoft Security Essentials to install over the existing installation. On the other hand, if you receive this error when installing Microsoft Security Essentials, download and run Microsoft Security Essentials Removal Tool to remove any leftover files from your computer.
Once uninstalled, restart your computer and install Microsoft Security Essentials again.
