Fail to play virtual blue ray disc player
Hello, I have an image of a blue ray disc but my virtual blue ray disc player does not play my image file. I don't know which of the two contains a damage. Can you help me identify? Thanks!
First of all you have to confirm the basic system requirements to play Blu-ray on PC. You can play Blu-ray on PC via Virtual Drive. You have to create ISO and mount it as a computer drive using virtual drive software. For home use Daemon Tools Lite is recommended and it’s free. Blu-ray players may recognize the virtual drive and play it as normal.
If your Blu-ray files are on hard drive, then you can convert them into ISO image and mount with Daemon Tools Lite using free DVD tool ImgBurn. UDF 2.5 file systemis required when you will convert Blu-ray file to ISO image.
