Failed to check for installed applications
Hello Everybody,
I was having Windows XP to be a dual boot with Feisty fawn. As a new user I’m getting error with my Feisty when tried to perform Add/Remove application. I’d follow some basic guide on updating and installing then I tried to input it into the terminal.
I do run first sudo apt-get update and followed by sudo apt-get install –f but no good output. I don’t have an idea of changing source list. Below is the error message.
Any help would be greatly appreciated.
Thanks!
Error:
Failed to check for installed and available applications
This is a major failure of your software management system. Please check for broken packages with synaptic check the file permissions and correctness of the file ‘/etc/apt/sources.list’ and reload the software information with: ‘sudo apt-get update’ and ‘sudo apt-get install -f’.
