Failed to communicate with radio error on CHIRP
Hello Everyone,
Here is my problem. Chirp 0.3.1 will receive configuration data from radio but fails to send back the chirp image to radio to complete the configuration. On Chirp, I select radio and choose upload to radio. The port, vendor and model are set to the same values that work for receiving data from radio viz. /dev/ttyS0, Yaesu, FT-60. Then I click OK to begin transmission. Chirp’s prompt appears showing that it is trying to transmit to radio but this halts soon after an error message’ Failed to communicate with radio’. What could be causing this error? Please help. I am waiting for your ideas. Thank you.
An error has occurred
Failed to communicate with radio: need
more than 1 value to unpack.
