Failed to create a report and try to view the SQL
I get the problem when I create a report and try to view the SQL or run the report because I get the incompatible combination of objects when I try to access an object from table that I added to a universe.
Thanks for any suggestion to resolve this annoying error message.
Warning
Refresh failed
Incompatible combination of tables.
