Failed to download Cities XL 2012
Hello!
I have a problem with Cities XL 2012 which I downloaded from their XL website. When trying to download the game with their suggested download manager, I clicked to install the game but I always failed with
Error has occurred, game cannot be launched message.
How can I fix it?
Answered By 10 points N/A #100329
Dear guy,all of we know that if there some files have been missed or corrupted in the application,may not be executed or launched. It is not wondering that some files may be missed due to internet connection problem or other. So you have to download the files and put together on the application folder.
Then try to install. Files may be missed or corrupted are: CitiesXL_2012_Setup.exe,CitiesXL_2012_Setup-1d.bin,CitiesXL_2012_Setup-1b.bin,CitiesXL_2012_Setup-1a.bin,CitiesXL_2012_Setup-1c.bin etc.
Try check file sizes by right clicking and then properties:
CitiesXL_2012_Setup.exe => 505 KB (517 944 bytes),
CitiesXL_2012_Setup-1d.bin => 1,18 GB (1 276 494 775 bytes),
CitiesXL_2012_Setup-1b.bin => 1,59 GB (1 708 200 000 bytes),
CitiesXL_2012_Setup-1a.bin => 1,58 GB (1 707 690 048 bytes),
CitiesXL_2012_Setup-1c.bin => 1,59 GB (1 708 200 000 bytes).
You can download Cities XL 2012 and try other download manager. This time no files may not be missed and you will able to launch Cities XL 2012.
I hope you will do well.
Good bye.
