Failed to export a vsd file to .erx format
We are working with database. While working we do not see the EXPORT option in the Menu Bar under Database column.
Due to this reason we failed to export a vsd file to .erx format.
Is there any solution which can enable the export option in the menu bar?
Hope for a positive reply from anyone.
Thanks and Regards
Answered By 10 points N/A #153203
Hello Cathy,
The following steps should help you perform the export of the .erx file without an issue:
  • First, you will open the Visio Database Model Diagram or ER Source Model that you would like to export.
  • After that you will choose Import/Export from the Database menu.
  • And then go to the Import/Export menu, and then choose Export ERwin ERX model.
  • After that you will choose a file name for the .ERX file, and then you will choose the version of .ERX file you want to create.
  • After that click OK to perform the export.
Carl
