Failed to import a Pivote .stk file
I just tried to import a Pivote .stk file but it gives the following error message saying “The file you selected cannot be imported because it is not a Pivot.stk file”.What should I do to fix this problem? Which files I have to import supported by this program? Can I get resolution in step by step. Thanks.
The file you selected cannot be imported because it is not a Pivot.stk file.
Answered By 0 points N/A #166868
The stykz application will help you import and convert your pivot 2 and pivot 3 .stk files. Go to stykz application > File > Import Pivot .stk File.
As an example you want to download figures, droidz.org is the most downloadable resource for pivot users. You can get animation figures from Droidz.org and download pivot .stk files and import them into stykz.
Go to the sticks page at droidz.org
Navigate to a category page.
Determine the stick you want to download.
If you move your mouse on info icon, a pop-up will tell you the file format.
Download and import the stick to stykz as mentioned above.
