I used PagePlus X6 before since it works fine with my Brother MFC-6490 AIO Scanner and also with my Adobe and Corel. However, when I used PPX7, I've got an error. Printing also works fine with PPX7 except for the scanner. But I don't want to change any of the scanner settings. How can I resolve this? The error given is:
PagePlus
Failed to initialize TWAIN.
Ensure that a 64-Bit TWAIN data source and driver are installed and configured.
OK
points
Failed to Initialize TWAIN on PagePlus X7
It’s very sad to hear about your driver. It would be better if you would stuck with PagePlus X6. However, there are fixes for PagePlus X7 that will fix several bugs. Download the proper one from here.
Also, the main problem of PagePlus X7 64-bit version is it can’t use TWAIN or WIA on 64-bit mode. So you have to install the 32-bit version. 32-bit programs run fairly on 64-bit OS so you’ll have no problem.
If you have installed the software in 64-bit build, you’ll find out two shortcuts:
PagePlus X7
PagePlus X7 (32-bit)
Start the shortcut of the second one listed above. Your tasks should go fine.
