Failed to install Borderlands, please help.
 I have a brand new computer that is operating on a Window 7 64-bit. I have been trying so hard to install the borderlands to the system but it hasn’t been a smooth ride. It executes an error: “borderlands.exe – Application Error”
 I have done extensive research from the internet but to no avail. Tell me please how to rectify this problem. Thank you in advanced.
Error:
The application was unable to start correctly(0xc000007b).Click ok to close the application.
Answered By 0 points N/A #145053
Some files are not available for the installer or that some access permissions are not given to a list of needed directories. These systems offer free usages to unmount the free storages and then install and mount them again. Thus the system requires privileges. The games sometimes do not run if they do not find some system files like the dll files. These files are used for providing inbuilt libraries for the system. The system utilizes the codes and then runs the software. You have to do the best work is to copy the installer and run it in the previous OS you were using. Thanks.
