I am getting the following error message when I try to install the iPPOTV (see figure below):
Error
Assertion failed!
Program:C:program [email protected]
File:player.cpp
Line:16
Expression:m_hModel
For information on how your program can cause an assertion failure,see the Visual C++ documentation on asserts.
Need your suggestion to fix it. Please help.
Thanks a lot.
Failed to install the iPPOTV
Hey Conan Herrera!
Well the reason behind this error is incomplete installation. There is a possibility that during setup, the installation wizard had skip some important files that are necessary to run the program.
Or there is also a possibility that these files are not included in your setup files. Anyways what you need to do is just to download a new copy of the software that would be of complete version. Then you have to remove the old installed program from the control panel > Add/Remove programs or programs and features (According to your windows). After uninstalling it, re-install the program that you have download from the internet.
It will fix the problem.
Thanks
