polymyth
Posted on - 02/09/2012
Failed to load Autodesk Inventor 2012 Installation
Autodesk Inventor Professional Suite 2012 Education Student Version system requirements:
Pentium 4, 2GHz, Intel Xeon, Intel Core, AMD Athlon 64, AMD Opteron, or faster processor
Windows XP Professional, 64-bit, Service Pack 1 or Service Pack 2
Windows XP Professional, 32-bit, Service Pack 3
Windows Vista Home Basic/Home Premium/Business/Enterprise/Ultimate, 32-bit or 64-bit, Service Pack 2
Windows 7 Home Premium/Professional/Ultimate/Enterprise, 32-bit or 64-bit
2 GB RAM or more recommended
Microsoft Direct3D 9 or 10 compatible video card
DVD optical drive
1280 x 1024 screen resolution
Adobe Flash Player 10 or higher
Microsoft Internet Explorer 6 until 8
Microsoft Excel 2003 until 2010 for spreadsheet-driven designs
Microsoft .NET Framework 4.0
It doesn’t matter what version of Windows you are using. It will automatically be detected during installation and the appropriate version of the application will be installed.
Windows Vista users need to install Hotfix KB971138 to be able to install this software. And since you are having some problems in installing Autodesk Inventor 2012, please check if you have already installed Microsoft .NET Framework 4.0.
If you haven’t installed it yet, cancel the installation of Autodesk. Install Microsoft .NET Framework 4.0 first. This is required in the installation of Autodesk. After installing Microsoft .NET Framework 4.0, you can now proceed on installing Autodesk Inventor.
I think you need to free some space from your temp folder. This error is may generated due to low disk space. Follow these steps:
1) Click start and write "%TEMP%" in the search option.
2) Now in the temp folder, select all the temporary files and delete them.
This generated error may be due to the runtime error of these 3 programs:
1) .Net framework
2) Microsoft Visual C++ Redistributable
3) Microsoft SQL server 2005
You should see if these programs are not getting runtime error and try reinstalling your Autodesk again.
Hope this helps
