Failed to load GROWL framework
I am having issues using GROWL SDK and getting the error saying “Failed to load GROWL framework”. I followed the instructions to load framework but I was unable to continue my work. Help me to solve this problem. Any help would be appreciated.
Thanks in advance.
Failed to load GROWL framework.
Answered By 0 points N/A #181889
To avoid this error follow the steps below:
Download the latest Growl Sdk and and put Growl-WithInstaller.framework in the frameworks folder.
Go to Project, drag and drop Growl-withInstaller.framework directory to “Framework”.
Link Frameworks and Libraries, create a new build phrase and Copy files.
Drag Growl-WithInstaller.framework from left side of project navigator to the column row.
Finally set Destination to Frameworks and keep Copy only when installing Unchecked, otherwise you would get error.
