I just started my computer and tried to load Opera but an error message displayed on the screen saying ‘failed to load opera’. You can see the whole error message below. I have searched the solution from google but can’t find any resolution. I just rebooted my computer but the same error appeared. What should I do now to resolve this error message? Thanks for help.
Opera Error
Failed to load opera.DLL because:
The specified module could not be found.
Failed to load opera has occurred
The Opera is missing some of its important files. So the problem is occurring. Already the first aid had done by you. So at this time you need to repair the Opera. Or, reinstall the browser to fix the problem. The reinstall is better than repair. So you can reinstall the opera software.
Hi Carol K Simons,
The error might be caused by a bug in the version of Opera you are currently using. Try to do the following to fix the problem:
1. Look for a newer version of Opera.
2. Download the latest Opera update and install it to your computer.
3. Restart your computer after the download finish for the changes to take effect.
4. Try to run Opera again.
Hope this works.
Murakami Wyatt
