I'm sure others will have already asked how stop the above warning from happening, the previous thread is expired. I would be very, very appreciative of the advice. Plus I have tried followings:
The lowest level of security setting, enable on all boxes.
Turn off information bar.
Turn off Pop-up Blocker
Also make the website as Trusted site
All failed
Failed to load popup blocker assistant activex control
Try the below procedure. Please do the procedure step by step it will make easy.
Open Internet Explorer.
Tick Tools on menu bar.
Tick Internet Options…
The Internet Preferences window appears.
Tick the Sanctuary tab.
Tick the Custom Level… button.
The Safekeeping Settings window appears.
Locate ActiveX controls and plug-ins in the Settings: list.
Tick to select Enable under Automatic prompting for ActiveX controls.
Tick the OK button.
A Warning! A memorandum appears.
Tick the OK button to change the security settings for the zone.
Tick the OK button.
You will now receive prompt directly from a Web site if it needs to copy software to your computer. And this will solve your computer.
And your problem will be solved.
