Failed to open a connection to the database Error message
10 points
Posted on - 08/14/2011
Hi There,
I started my day with an error message with Microsoft Visual Studio. I have Microsoft Visual Studio 2010 installed on Windows Vista machine. Occasionally, I had been getting error messages while opening the application. But today when I attempted to connect it with my SQL database, it came up with an error message that it would not connect.
I tried changing the login credential details but it is still the same.
For more details, check out the error screenshot below:
Error message: ‘Could not find a part of the path F:Program Files
(x86)Microsoft Visual Studio
10.0VSTSDBMicrosoft.VisualStudio.Data.Schema.SEExtensions.xml’. Â
at DataViewSupport(4,3)’
Check the connectivity and try again.
                               OK
