Failed To Open Data Stream Error Code 0x000B03E9
When I try to delete a backup edition from the Acronis True Image Home 2011 I am getting the following error message:
Acronis True Image Home 2011 Fails to Delete Backup or Create an Incremental Backup
Causes: other software (e.g. Using earlier version, antivirus, window explorer etc)
To solve this issue:
1. Is your version of Acronis True Image Home 2011 is earlier than Build 6868:
Then Update Acronis True Image Home 2011 and try to delete a backup version again. Check this site for updates: :
2. If Build 6868 is installed,
Check and unlock your archive if it is locked by another software (e.g. antivirus/window explorer)
3. You can add tib files and/or your backup locations to exclusions in your antivirus settings.
4. Also, you can restart your computer to force applications to release the backup file.
Notifications
