Failed to Run Task Sequence While Deploying an Image
I want to use the image I created and deploy it to my production floor inside my test environment. For this I use a WDS server. Normally what I do is copy the wim file over, import it, and all goes well. Everything was running smoothly till I got the following message. It partitions and formats the C drive. And then it automatically copies the image and starts applying the image phase. Then it displays 5 blue bars and I get a Task Sequence Error. I have researched this code for a week now but I can’t find a valid reason or any help. Please help me on this. Thanks for reading and I appreciate your efforts.
