Failed Sending file using Yahoo Messenger
Here is my solution for this question
Step 1: Open your yahoo messenger and log in to your account.
Step 2: Select the contact which is you send the file.
Step 3: Double click on the contact and click the symbol this picture below and finally wait some time and its send automatically.
Hi Johan,
You might have a firewall problem. So, check your firewall setting .There are a large number of reasons for this error. I suggest you to send as attachments. You can choose the help of yahoo. Go to your account and report to the yahoo which may be very helpful for you. Also you can try by updating yahoo messenger. Network shield might block your yahoo messenger.
I think it's may be helpful for you.
