Failed to Sync my Pocket PC
I am using a Personal Digital Assistant (PDA) and AvantGo service for syncing my pocket PC. I am trying to sync a certain website without luck. There are numerous errors when synchronizing my PDA. What should I do?
Answered By 75 points N/A #115063
Hi Grace Begum,
What are some of the errors that you are receiving? That will be able to give us the head stats to solving your problem. But some of the basic things that you should check are that you are able to establish a connection between the PC and your pocket PC for the synchronization to be successful.
If you are connecting the two devices using a cable then make sure that there is not problem with the ports or the cable connecting the two that may be hindering a connection to be established. Check also that you are able to establish a connection in case you are using Bluetooth to connect.
Hope this helps.
_
Regards
Lee Hung
