Failed to update NFS World beta.
 Hello guys,
I have downloaded as well as set up the 8 MB vast Install data. After joining to the NFS World beta I selected the UPDATE key but NFSW displays an error.
I’ve attached a screenshot of it:
There has been an error downloading the game, please make sure that your connection is working and retry.
I’m not sure what it indicates. Also my internet connection is good, otherwise I am not able to browse the NFS World site.
Can anyone share a suggestion? I ‘d be gladly accept any advice from you.
Thanks for help.
Answered By 590495 points N/A #144595
I suspect that this problem is caused by a system incompatibility problem but after checking the game’s specifications, it turns out that your operating system is pretty much supported by the game. If this is the first time it happened with your Need for Speed World game client, try restarting your computer then try it again. It should work if ever your system doesn’t have any other problems.
Need for Speed World works on Windows XP [Service Pack 3], Windows Vista [Service Pack 2], and Windows 7. If you are sure that there is no problem with your internet connection, you may try doing another clean installation of the game client just to restore it to its default configuration and fix any corrupted files that may have accidentally developed during your previous installation. Uninstall Need for Speed World game client then check your computer for any possible errors. Use a disk utility application to check the system. After this, install Need for Speed World again.
To know more about the technical specifications of the game, you may visit EA — Need for Speed World Minimum Specs.
