MARYBOO
Posted on - 08/12/2011
I have a Windows XP pro 2000 and my updates failed. Can someone please help? System restore doesn't do anything. It goes through and comes back 'Have not restore'.
Please can someone help?
God Bless!
Ken Mark
10 points
Failed Updates And My SYSTEM Restore?
There are several software that may restrict along 'System Restore' in normal or protected mode creating a restoration to unsuccessful. First try operating method recover within secure mode. This may conquer the interference and permit the particular repair to finish successfully.
Note: Good Undo options bring back level will not be immediately created whenever method restore is operated inside secure mode. To possess a current recover point to fall back on, produce a manual bring back part of typical setting just before coming into safe mode.
Your issue might occur as Wups2.dll file is incorrectly installed in your machine. To rectify this issue you can do either of the followings.
Download Windows update Agent and then install it.
Register this incorrectly installed Wups2.dll file. To register Wups2.dll follows the instruction below.
In command prompt >>key “net stop wuauserv“and enter (This will stop automatic updates service)>>key “regsvr32%windir%system32wups2.dll” and enter>>if any alert message of success received click ok>>key”net start wuauserv” and enter
