Hello All,
I installed both the Blu-ray and DVD converter V3.0.0.4b. The Blu-ray works fine but the DVD Converter gives this access violation error message when trying to launch and fails to launch. I was able to launch DVD Converter V3.0.0.3b without any problem. It is only when I tried the V3.0.0.4b version that I ended up with this error. I tried running the installer again but without any success. Is this installer corrupted? How can I get DVD Converter V3.0.0.4b to work? At present I do not have the installer for the V3.0.0.3b with me. Please help me to fix this issue. Thanks in advance.
Exeption EAcessViolation in module DVDConverterUltimate.exe at
0
Access violation at address 00000000. Read of address 00000000.
Fails to launch DVD Converter with Access Violation Error
Though I’m not sure if you are using the beta version of DVD Converter because I saw “b” in there, try upgrading to the latest version since you are still using an outdated version. Download the latest version from DVD Converter 3.2.0.6. It supports Windows XP [x86 only], Windows Vista, Windows 7, and Windows 8 both x86 and x64.
There are no other required components that needs to be installed for the program to work such as Microsoft .NET Framework and others. See if this fixes the problem. Since I think you are using Windows Vista or Windows 7, try running the program as administrator. Right-click on the program’s icon and then select Properties. Select Compatibility tab, under Privilege Level, check “Run this program as an administrator”, and then click OK. Try it again and see if it works.
You also don’t need to install any additional codec for the program. But in case you are converting from a protected DVD, you need to download and install a DVD Decrypting Tool. The provided link gives four different decrypting tools but I’m not sure if the other three are also freeware. Just check the page for instructions on how to use the tool.
