Fails to start Stykz after power interruptions
Hello Guys,
These error happens when I’m at a middle of my editing project when power interruptions comes then switch on again the desktop and fails to start Stykz.
How can I resolve this error?
How can I retrieve the unsaved files? If there’s an option can you please guide me?
I would really appreciate all inputs.
stsFWExternals: Stykz.exe – System Error
The program can’t start because QTCF.dll is missing from your computer. Try reinstalling the program to fix this problem.
OK
Answered By 10 points N/A #118588
Every time you see an error message and indicates something to do with the*.dll files, then that problem is being caused by some issues in the registry entries of that application. or possibly an infection on your computer by a virus. And therefore the workaround should be countering these two.
  • First you will need to perform a full scan of your system to remove any viruses that might be affecting some programs on our PC and even messing up the registry entries for some applications like the one above.
  • In case there are some changes you did to the system that you suspect might have caused the registry entries for the application to be corrupt, then I will suggest that you run system restore to remove those changes. Restore the system to  a time before the error started occurring.
Regards
Thompson Locker
