Failure to complete Iclone installation
Dear Friends,
Here is my problem. I was able to download Iclone 4.3 without any issues but while trying to install the same, I get an error telling me that the medium from which I tried to install is corrupted. I checked to see if all my local software (flash, .Net etc) was up to date. After verifying this I tried downloading the installer using chrome and then tried to install Iclone. Again I get the same error as in the first case where I downloaded using FireFox. What is to be done? What else could be wrong with my system? I am using MacAfee antivirus in my computer. Please give me some ideas on how to solve this issue. Thanks a lot.
CrC error: The file C:Program FilesReallusioniclone 4RLVnsRepackerUT.dll
doesn’t match the file in the setup’s.cab file. The medium from which you are
running the setup may be corrupted; contact your software vendor.
