Failure importing IFC files to ArchiCAD
Hello All,
I face an issue with importing ifc files to ArchiCAD since updating my IFC export plugin. The export plugin seems to have stopped working and I get an error every time I try to import. The message reports an inconsistency during IFC file read operation and elements are not imported at all or only half gets imported. I used Open command to launch IFC model as a separate ArchiCAD file independent of any other project. Then I attempted importing the file to my project as a Hotlinked module. But somehow this does not work for me. Can anyone please help me with importing of IFC files? Thank you for spending your time on resolving this issue.
Image:
Error:
Warning: Inconsistency found during IFC File read operation. For further information check the report window. Do you want to continue?
