Failure to install the Access Management Console Version 4.6
I have failed to install the Access Management Console Version 4.6. What could be the reason? Please, help me in this regard.
Error:
Installation failed
Error:
Installation failed
Dear Stanley steward,
Your problem is Access management Console installation failure.
Here is your solution. Just follow the instruction.
01. Firstly you have to uninstall Access management Console which was not completely installed.
02. Go to Local disk C, then Program files, and then delete the folder Access management Console.
03. Now restart your computer.
04. Now you have to install Access management Console.
05. First you download the latest version of Access management Console.
06. Extract the transform file, CDFFix.mst, and copy it to a local temporary directory.
07. Launch Access management Console 4.6 Framework installation using the following command.
Msiexsc.exe/I”D:Access Management ConsoleASC_Framework.msi” TRANSFORMS=”C:tempCDFFIX.mst”/I*v C:tempamc.log
08. Resume the access management console installation by using following command
“D:Access Management ConsoleCtxInstall.exe”
Follow the instruction; I hope the above information will help you to solve your problem.
Thank you.
