Failure to install Apple Final Cut Studio 3 on MacOS
I have been trying to install Apple Final Cut studio 3 and I keep getting this error message saying that the source media is damaged. I am working on Mac OS X 10.5.1. Someone suggested trying to clean the disk I am trying to install from using a dry lint free cloth. I tried this method and found that nothing changed. However when I tried to use the same disk to install on an iMac G5, there are no issues!!! But on my 10.5 machine, once the audio content 1 disk is done with, it asks for the original final cut install disk and gives the error message. What could be wrong? Is this a compatibility issue? Please help. I am clueless as to how to fix this problem. Any help will be greatly appreciated. Regards
Image:
Error:
Installation had errors
Installation failed
The source media you are installing from is damaged. Try installing from a different copy of the source media or contact the manufacturer for a replacement.
