Failure to launch Help Client message from Adobe Encore
Hello Experts,
I get a ‘Failed to launch Help Client’ error message when I launch the help client in Adobe Encore CS6. I tried uninstalling and reinstalling this software a couple of times. But every time, I end up this error message. Why is the Help Client refusing to launch? I find that in my most recently downloaded version of Encore, the Help Manager is also present. What else can I do to fix this issue? Can someone suggest a way to manually copy the missing file alone to the specified location, so that I need not go in for another uninstall, reinstall and discard the downloaded version cycle? Thanks a lot. Regards
