Failure of Satellite to Launch saying Access Violation
TypingMaster pro is the software which can be controlled online with the help of licenses provided at the time of purchase.
As per viewing this question, i think that you are getting this error because you have already installed the previous version with your purchased license in the system, and now you are trying to use its advance version, let me tell you that to continue using typing master with higher version will require to uninstall the existing version, and then try to install it again….
Please note the license no. with yourself for further process. When you uninstall the previous version, your license will be free to use again in upgraded version.
hope this will work.
Thanks
Notifications
