How to remove Fake Adobe Update Virus
I think my computer is infected with malware or a virus that I cannot define. This happens after downloading Adobe Flash Player Update which I think is a legit version from Adobe itself, by the look, you really can't tell that this is some sort of a virus. After downloading the update, my computer shuts down and I could not open it to my windows again.
I open it again, and I can just reach until the Windows XP loading window. After that it restarted again then an error appears that my windows failed to start. I hit the F8 key upon restarting then boot to safe mode then uninstall that Adobe fake update. But seems like the virus spread to my windows and i could not open it normally again.
Warning
Security tool successfully installed!
I tried to repair my computer, but it doesn't help at all. How can I remove the virus? This seems to be a strong malware or something. I am using Windows XP Home Edition Service Pack 2. I already scan my computer, but the malware cannot be detected. I am using AVG Free Edition.
How can I completely uninstall this rogue virus?
Please take note that I can only open my computer on safe mode which has a very limited access.
