Fake folder are not find out.
Asked By 7060 points N/A Posted on -
When I installed Avira antivirus on my PC further time I saw Fake folder setup file don't show in my PC.
Best Answer by Sandra R Butters
Answered By 30 points N/A #84455
Whenever you install any kind of antivirus on your system the first thing it does is to scan your computer and check for virus. If any suspected file are found it deletes them by giving intimation. Same is the case with your Fake folder setup file. Avira might have been deleted the file considering that as a spam file.
Thank you.
Answered By 30 points N/A #84456
Antivirus software basically runs in the background on the computer and scans every opened files and folders from virus or any kind of spam. So it might be possible that Avira finds the folder as a spam or virus and deleted it. But if you want to keep this type of folder then you can use folder lock software. This software is available in the internet and you can get it for free. Hope this could be a help.
Thank you.
