Famous Toshiba bulletin board alternative
What other Toshiba bulletin board alternatives are famous to use in emergency? Sometimes, my Toshiba bulletin board show pop ups, so I have to face internet speed problem.
You can turn your Toshiba bulletin board pop ups by simply turning off the associated service for Toshiba pop ups. Follow these steps to turn off desired services:
Hi Dennis,
If you are having troubles with your Toshiba bulletin board, I suggest that you either get it fixed or download another one.
To turn off those annoying pop ups, here is what you can do:
1. Go to START button, type MSCONFIG then press ENTER.
2. You now have the System Configuration box. Go to STARTUP tab, uncheck MESSENGER.EXE (or message center)
3. Click OK
Restart your pc and open up your bulletin board. You should not get pop ups anymore.
But if the problem persists, Click on this link and it will direct you to a website where you can browse for a compatible bulletin board for your Toshiba.
