I am trying to start Farm Ville application which requires Adobe Flash Player but it displays as crushed as you can see in error image. I reinstalled the Adobe Flash Player but the same error displayed.
How can I fix this annoying error message without having any issue?
I need your help. Thanks!
The Adobe Flash plugin has crashed.
Send crash report
Farm Ville Adobe Flash Loading Error
FarmVille Adobe Flash Plugin Loading Error
Hi Alexander!
Many people have encountered this problem while playing Flash games. One solution that worked for many that use Firefox is to go the Internet Explorer 8 browser, select Tools and then to click Manage Add-ons. There, Adobe may be disabled and this is what may cause the problem.
Go back to Firefox and download again the latest version of Flash from the Adobe page, since older versions may crash when playing games. Be careful when downloading, because it may ask for an extra confirmation.
Other solution would be to disable your firewall in Internet Explorer, because it may also block Zynga applications.
If any of these doesn't work, try and uninstall and reinstall the browser you're using, it may help.
Hope this was helpful!
