Nowadays I faces a big problem to use broadband connection.
Sometimes it is become so fast and sometimes it becomes so slow do not know why it occurs.
Again when I use modem or another system there also better to use.
What is better in this modern age?
Fast and Slow internet broadband connection
In peak hours the network traffic is maximum and that's why you don't get better speed over the network and in normal hours when there is no network traffic then you get a good speed form your service provider. In this case you can either change your service or you can use a connection that best supports your requirements.
If you are using a modem then the speed may be vary over time because over a telephone network there is a lot of users and each one wants to connect that service because of these number of users you are not able to get maximum speed.
So you can buy another service to get maximum speed or you can simply wait for the time when there will be not traffic over the network.
To see your connection speed press ALT + CTRL + DEL form your computer at the same time and then go to network tab and you will be able to see your network speed over a period of time. Then you will be able to enhance your network speed.
Michal joran.
It depends with the speed at which the broadband can upload and download files from the internet. If for instance the broadband that you are using has a download speed of about 20 MBPS, then you will not expect it to browse at the same speed as the modem if the modem has a download speed of about 100 MPBS.
Some of the activities that will make the broadband speed to slow down are:
Having many downloads queued at the same time.
Browsing using multiple tabs which take a lot of bandwidth when loading.
Uploading many files on the internet at the same time.
You will need to reduce browser activities, uploads and downloads for you to get the best out of your broadband.
Thompson Locker
