Hi People,
When I try opening Verizon PC app or play a game, I get the following error message I need to resolve this issue, any help will be appreciated
Thanks for all help.
Fatal error
Missing required resource!
Try to reinstall EXEtender.exe from your service provider’s web site
Fatal error – Missing required resource!
“Hello”,
“The Fatal Error occur as it cannot find the EXEtender.exe file or its not running properly on your system so to solve this issue you need to download the EXEtender.exe file from the internet
You can use the following link to download this file:
http://vztdata.exent.com/Prem/Verizon/V5/downloads/EXEtender.exe
After completing the download you have to save the file in the location of you download and then run this file, running this file will reinstall the PC app and your issue will be solved.
To run the file double click on the EXEtender.exe
Good Luck!”
