Fatal error in opening file.
Posted on - 02/08/2013
I got a fatal error while opening a file that I worked on some days ago; at this time I receive a fatal Error at the exploring. I attempted to explore the .ma file build in the temp folder with the script editor on to view the omission is where, and that is the outcome is the attached picture.
I have also put out of action the cycleCheck -me like it said on the caution box however it did not work, on this task the single “strange” item I have used is the MJPolyTools.
Expect you will really help me
