Fatal Error Problem for Adobe Captivate
Adobe Captivate has encountered a problem. It is showing an error message with a fatal error.
Though the error message has assured to save all my works, I found nothing saved at the direction.
I restarted my system, and it was working well.
Have you any idea for the issue?
Please help.
Thanks in advance.
A fatal error has occurred, and the application is being terminated. Adobe Captivate has tried to save all your work in the respective project folders as “.cpbackup”files.
Please restart Adobe Captivate.
