Hello friends,
Recently I downloaded a new game from the trusted website and it went pretty well and good without any problem. The real problem triggered while I try to install it. For your information, I have Windows operating system 64-bit and 500 GB hard disk and I upgraded my system recently. Please explain me how to fix this problem. Thanks.
FATAL ERROR
FATAL ERROR: Renderer #0
Could not be initialized! Make
sure your graphic card drivers are up to date. Check log file for more information.
points
Fatal error Renderer #0 could not be initialized
Your problem indicates to rendering issue. This usually happens due to bad graphics card driver or older driver. It is recommended to install the latest graphics driver because they includes various fixes and improvements and more supports for existing hardware. It also allows software to work smooth with the graphics card.
Depending on your graphics card, download the driver.
Also, update your DirectX. Download DirectX.
If no solution, check your game installation. It is, sometimes, the main cause for such issue. Uninstall the game and then re-install it from the installation source.
Also, try to update your game. Download its patch.
