FATAL ERROR Security system is not functioning or is improperly installed
I have this error and I did everything that I know to solve it. The reinstall is not helping, a custom install is not helping. The problem is when I click OK I can continue to work for a while but it appears again and it’s started to be very annoying. Does anyone have a solution for this error ? What should I do ?
Thank you !
FATAL ERROR: Security system (hardware lock or network license) is not functioning or is improperly installed.
