Fatal Error on Showcase and Inventor 2012 Installation
I got a Fatal Error on installing Autodesk Showcase 2012 and Inventor 2012. I tried to install for few times now and the same error incurs. What can I do?
I think fatal error is an error generated from within the program. Incompatible system is also one of the reasons for this type of error. Before installing Autodesk Showcase 2012, you must first need to know its system requirements so you will know if your operating system can be able to run this application.
Autodesk Showcase 2012 can be installed on a computer that runs on Windows XP Professional 32-bit Service Pack 3 or higher, Windows XP 64-bit Service Pack 2 or higher, Windows Vista Business 32-bit or 64-bit Service Pack 2 or higher, and Windows 7 Professional 32-bit and 64-bit. Your computer must have at least a Pentium 4 processor, or an AMD Athlon that supports SSE3. Your system must have a minimum of 2 GB RAM installed on it or more recommended. It requires 20 GB of available hard drive space.
Check your hardware base on the information above. You may also try checking your computer for any possible errors.
