limadeson
Posted on - 12/14/2011
When attempting to start AutoCAD, an error message says ‘Fatal error : Exception at 7c81eb33h. AutoCAD is aborting because the software is generating an exception which cannot be able to handle’. Please help me to get out of this problem. I will be thankful for all the help and support.
Fatal Error on starting AutoCAD
Issue
When you launched the application, you received the following error messages:
Fatal error: Unhandled e0434f4dh Exception at 7c81eb33h
Application has generated an exception that could not be handled
Process id=0xeec (3820), Thread id=0xc8c (3212)
Solution
These errors at startup indicate that the required .NET Framework components are either not installed or they are not operating correctly. To resolve these errors, you must make sure that the following .NET Framework components are installed. Follow these steps:
On the Start menu (Windows), click Settings > Control Panel.
In Control Panel, double-click Add or Remove Programs.
In the Add or Remove Programs dialog box, locate the following components. If you are not able to locate these components, you need to manually install them.
Microsoft .NET Framework 1.1
Microsoft .NET Framework 1.1 Service Pack 1
Microsoft .NET Framework 1.1 Hotfix
If installing the correct components does not resolve these errors, you can download and install .NET Framework 2.0.
