Fatal Error on starting Civil 3D 2012
When starting Civil 3D 2012, I got this “FATAL ERROR: Unhandled C0000417H Exception 72258293H”.
And then, it will automatically close when I clicked on the OK button.
Any ideas?
Any ideas?
Please check the system compatibility of the software, The only solution that I found that is he upgraded his computer the complies with the system requirements of the autocad 2012 and he also upgraded his operating system to windows 7. But also check the bit requirement of the civil 3d 2012 program it may refer to 32-64 bit system. This is only a hardware problem that is occurring please have a knowledge on the system requirements that is being given by the software this is to make the software run in a good and smooth program have a good day and enjoy your stay here.
If you are receiving a fatal error message when starting Autodesk AutoCAD Civil 3D 2012, I guess you better check if your computer is compatible to run the software. For the 32-bit version of Autodesk AutoCAD Civil 3D 2012, your computer should be running on Windows XP Professional Service Pack 3, Windows Vista [Enterprise, Business, or Ultimate] Service Pack 2 or higher, or Windows 7 [Enterprise, Ultimate, or Professional].
For the 64-bit version of Autodesk AutoCAD Civil 3D 2012, you should be using 64-bit Windows XP Professional Service Pack 2 or higher, Windows Vista [Enterprise, Business, or Ultimate] Service Pack 2 or higher, or Windows 7 [Enterprise, Ultimate, or Professional]. If you have a compatible operating system but incompatible Service Pack, simply update your operating system to the latest available Service Pack and it should fix the problem.
If you are using an incorrect or unsupported edition of Microsoft Windows, I guess there is no other way but to replace your operating system. The minimum processor supported by the application is Intel Pentium 4 1.6 GHz or faster with SSE2 technology. For the 32-bit edition of Autodesk AutoCAD Civil 3D 2012, the minimum required RAM is 1 GB.
For the 64-bit edition of Autodesk AutoCAD Civil 3D 2012, the minimum amount of RAM is 4 GB.
