Fatal Error: Unhandled e0434352h Exception at 75869617h
Hey Everyone,
I was using my Autocad 2012 (32bit) then received the error message which reads: "Fatal Error: Unhandled e0434352h Exception at 75869617h ". It happens even on the smallest commands.
I have recently formatted my computer in an attempt to fix the error but it still didn’t work.
My system configuration now reads:
Processor : Intel Core I5 @ 3.3 Ghz
Ram : 4GB
Display Adapter : 1GB Geforce
Antivirus : KIS 2012
OS : Windows 7 Ultimate 32bit.
Please help me. Thanks so much in advance for giving help to me.
Best Answer by shovon_7
Answered By 0 points N/A #191681
Hello Green,
You will need to check the following:
  • If you have tried installing that on all drawings, also on brand new ones based on an original AutoCAD template.
  • Also check if you have verified that you have installed all service packs that are available for your AutoCAD version.
Nicke
Answered By 0 points N/A #191684
Hi Green Scoot,
It can happen for the presence of misconfigured database on your computer.
You can try repairing them either by uninstalling the software first & then a fresh install may do the trick.
Alternatively, you can check for the latest bug fixing update for autocad 2012 here:
Try installing it as it may contain the solution to your problem.
Alternatively, you can always try the "about" section which can be found by – "Menu: Help>about" for any info regarding any problem of your autocad 2012 software.
Hope this helps!
